跳转到主内容
Removal of super-vario 40 braille display
你所需要的
  1. Removal of super-vario 40 braille display, Removal of super-vario 40 braille display: 步骤 1 中的图像 1,2 Removal of super-vario 40 braille display, Removal of super-vario 40 braille display: 步骤 1 中的图像 2,2
    • Remove the four bottom screws with a Phillips #00 screwdriver.
  2. Removal of super-vario 40 braille display: 步骤 2 中的图像 1,3 Removal of super-vario 40 braille display: 步骤 2 中的图像 2,3 Removal of super-vario 40 braille display: 步骤 2 中的图像 3,3
    • Remove the plastic cover, paper and chipset.
  3. Removal of super-vario 40 braille display: 步骤 3 中的图像 1,3 Removal of super-vario 40 braille display: 步骤 3 中的图像 2,3 Removal of super-vario 40 braille display: 步骤 3 中的图像 3,3
    • Remove the two screws with a Phillips #00 screwdriver on the logic board.
    • take out the main circuit like show in the picture
  4. Removal of super-vario 40 braille display: 步骤 4 中的图像 1,3 Removal of super-vario 40 braille display: 步骤 4 中的图像 2,3 Removal of super-vario 40 braille display: 步骤 4 中的图像 3,3
    • Remove the four screws with a Phillips #00 screwdriver.
  5. Removal of super-vario 40 braille display: 步骤 5 中的图像 1,3 Removal of super-vario 40 braille display: 步骤 5 中的图像 2,3 Removal of super-vario 40 braille display: 步骤 5 中的图像 3,3
    • Remove the connector delicately.
  6. Removal of super-vario 40 braille display: 步骤 6 中的图像 1,2 Removal of super-vario 40 braille display: 步骤 6 中的图像 2,2
    • when you put it back together make sure mechanical cells are connected correctly
结论
另外一个人完成了本指南。
Sisyphe
于07/29/13注册
350 声望
创作了2篇指南
2条评论
great guide!  how can I repair a VarioUltra 20?  are the procedures similar?  the device has a problem at point 4 of the sixth cell, the point moves unsteadily, should I replace this whole cell or is it possible to just repair point 4, which is defective?
marcusvinicioslira - 回复
which professional will likely be able to repair a braille display?  should I look for an electrical engineer or other professional?  I'm blind, I don't repair electronics, but I have a defective braille display that needs to be repaired.  I live in a country where there are no companies capable of repairing this product.  I do not know what to think.  sending the product to a specialized company in another country is very expensive for me.
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 991
