跳转到主内容
CyberpowerPC Fangbook HX6 Screen Replacement
你所需要的
  1. CyberpowerPC Fangbook HX6 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • To replace the screen you will need a screwdriver (a size zero was used in this guide), and a tool that can be used to pry off the screen covering (a spudger was used in this guide).
  2. CyberpowerPC Fangbook HX6 Screen Replacement: 步骤 2 中的图像 1,3 CyberpowerPC Fangbook HX6 Screen Replacement: 步骤 2 中的图像 2,3 CyberpowerPC Fangbook HX6 Screen Replacement: 步骤 2 中的图像 3,3
    • Insert the spudger gently into the seam that connects the front plate to the rest of the device.
    • Move the tool carefully around the screen and apply a small amount of pressure. You are trying to undo several clasps holding the front plate on.
    • Do this on all sides of the face plate except for the bottom. The bottom will have a strip of adhesive you will need to carefully pull off to separate the face plate from the bottom of the screen.
  3. CyberpowerPC Fangbook HX6 Screen Replacement: 步骤 3 中的图像 1,2 CyberpowerPC Fangbook HX6 Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the two 4mm silver screws on both sides of the top of the screen.
    • Once you have removed them, gently pull the screen off of the aligning dials (the small plastic pieces to the left of the screws).
  4. CyberpowerPC Fangbook HX6 Screen Replacement: 步骤 4 中的图像 1,2 CyberpowerPC Fangbook HX6 Screen Replacement: 步骤 4 中的图像 2,2
    • At this point the only thing keeping the screen attached to the laptop is this small wire and connector shown here.
    • Gently pull the screen out and turn it over so that you can see where the connector is attached.
    • Carefully remove it. Once this is done you have successfully removed the screen from your laptop.
结论
Eric Box
于09/12/18注册
159 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 19
总计 823
