跳转到主内容
CyberPowerPC RGB 7 Color Motherboard Replacement
你所需要的
  1. CyberPowerPC RGB 7 Color Motherboard Replacement, Plastic Casing: 步骤 1 中的图像 1,2 CyberPowerPC RGB 7 Color Motherboard Replacement, Plastic Casing: 步骤 1 中的图像 2,2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color Motherboard Replacement: 步骤 2 中的图像 1,2 CyberPowerPC RGB 7 Color Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color Motherboard Replacement: 步骤 3 中的图像 1,1
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color Motherboard Replacement, LED Backlight: 步骤 4 中的图像 1,1
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color Motherboard Replacement: 步骤 5 中的图像 1,1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color Motherboard Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the LED board, which should now come free from the casing.
  7. CyberPowerPC RGB 7 Color Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
  8. CyberPowerPC RGB 7 Color Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the motherboard and its attached cable from the plastic casing. The cord should now come free to replace.
结论
团队
USF Tampa, Team S15-G2, Boczar Spring 2018 USF Tampa, Team S15-G2, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 418
