跳转到主内容
CyberPowerPC RGB 7 Color LED Backlight Replacement
你所需要的
  1. CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: 步骤 1 中的图像 1,2 CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: 步骤 1 中的图像 2,2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color LED Backlight Replacement: 步骤 2 中的图像 1,2 CyberPowerPC RGB 7 Color LED Backlight Replacement: 步骤 2 中的图像 2,2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color LED Backlight Replacement: 步骤 3 中的图像 1,1
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color LED Backlight Replacement, LED Backlight: 步骤 4 中的图像 1,1
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color LED Backlight Replacement: 步骤 5 中的图像 1,1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color LED Backlight Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the LED board, which should now come free from the casing.
结论
2等其他人完成本指南。
Braydon Lantz
于02/12/18注册
229 声望
创作了2篇指南
团队
USF Tampa, Team S15-G2, Boczar Spring 2018 USF Tampa, Team S15-G2, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 35
总计 953
