跳转到主内容
CyberPowerPC Fangbook MS-1763 Key Replacement
你所需要的
  1. CyberPowerPC Fangbook MS-1763 Key Replacement, Key: 步骤 1 中的图像 1,1
    • Lift up the corner of your desired key using a spudging tool to create leverage.
  2. CyberPowerPC Fangbook MS-1763 Key Replacement: 步骤 2 中的图像 1,1
    • Apply lifting force to the corner until a portion of the inner key clips are detached.
  3. CyberPowerPC Fangbook MS-1763 Key Replacement: 步骤 3 中的图像 1,1
    • Repeat the previous step on all the keys corners and remove the key from its socket.
  4. CyberPowerPC Fangbook MS-1763 Key Replacement: 步骤 4 中的图像 1,1
    • Place your new key in the appropriate slot positioned as if the key was fully functioning.
  5. CyberPowerPC Fangbook MS-1763 Key Replacement: 步骤 5 中的图像 1,1
    • Apply force to the key until all key clips are properly attached.
结论
Terrias
于02/08/18注册
180 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 61
总计 740
