跳转到主内容
加入维修社区 - 创建账户
CyberPower UPS Battery Replacement
你所需要的
  1. CyberPower UPS Battery Replacement, Battery: 步骤 1 中的图像 1,2 CyberPower UPS Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Power down the unit by pressing the power button until the display goes black.
    • This is usually about 3 seconds.
    • Unplug the power cord from the wall outlet.
  2. CyberPower UPS Battery Replacement: 步骤 2 中的图像 1,3 CyberPower UPS Battery Replacement: 步骤 2 中的图像 2,3 CyberPower UPS Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the battery plate cover at the bottom of the UPS using a Phillips #1 screwdriver.
    • If the screwdriver is not magnetized, tap on the cover plate to completely remove the screw.
  3. CyberPower UPS Battery Replacement: 步骤 3 中的图像 1,2 CyberPower UPS Battery Replacement: 步骤 3 中的图像 2,2
    • Slide the battery cover plate to the left.
    • Grasp the battery plate cover and lift it off the the UPS.
  4. CyberPower UPS Battery Replacement: 步骤 4 中的图像 1,3 CyberPower UPS Battery Replacement: 步骤 4 中的图像 2,3 CyberPower UPS Battery Replacement: 步骤 4 中的图像 3,3
    • Pull out the battery to expose the terminal connectors.
    • Use needlenose pliers to disconnect both battery terminal connectors.
    • Do not pull the connectors by the wires, pull connectors by grabbing the connector itself.
    • With the battery terminal connectors disconnected, slide the battery all the way out.
  5. CyberPower UPS Battery Replacement: 步骤 5 中的图像 1,3 CyberPower UPS Battery Replacement: 步骤 5 中的图像 2,3 CyberPower UPS Battery Replacement: 步骤 5 中的图像 3,3
    • The replacement battery should be a 12 volt, 9 amp-hour, sealed lead acid battery with f2 type connectors.
    • Install the new battery and reconnect the terminals.
  6. CyberPower UPS Battery Replacement: 步骤 6 中的图像 1,3 CyberPower UPS Battery Replacement: 步骤 6 中的图像 2,3 CyberPower UPS Battery Replacement: 步骤 6 中的图像 3,3
    • Insert the screw to secure the battery cover plate.
    • Tighten the screw with a Phillips #1 screwdriver.
  7. CyberPower UPS Battery Replacement: 步骤 7 中的图像 1,3 CyberPower UPS Battery Replacement: 步骤 7 中的图像 2,3 CyberPower UPS Battery Replacement: 步骤 7 中的图像 3,3
    • Plug system into the wall outlet.
    • Press the power button to turn on the unit.
结论
3等其他人完成本指南。
1指南评论
This guide is very educative and helpful.
Philip Saviour - 回复
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 79
过去 30 天: 318
总计 18,499
