跳转到主内容
CyberHome CH-DVD 300 Back Panel Replacement
你所需要的
  1. CyberHome CH-DVD 300 Back Panel Replacement, Top Panel: 步骤 1 中的图像 1,2 CyberHome CH-DVD 300 Back Panel Replacement, Top Panel: 步骤 1 中的图像 2,2
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. CyberHome CH-DVD 300 Back Panel Replacement: 步骤 2 中的图像 1,2 CyberHome CH-DVD 300 Back Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. CyberHome CH-DVD 300 Back Panel Replacement, Back Panel: 步骤 3 中的图像 1,2 CyberHome CH-DVD 300 Back Panel Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Remove the remaining screws on the back of the DVD player:
    • There will be four 15 mm screws and two 6.3 mm screws.
  4. CyberHome CH-DVD 300 Back Panel Replacement: 步骤 4 中的图像 1,1
    • Remove the back panel by:
    • Lifting up on the back panel.
    • Pulling the back panel backwards from the DVD player.
结论
另外一个人完成了本指南。
Chris Menezes
于04/07/14注册
687 声望
创作了5篇指南
团队
Cal Poly, Team 6-5, Forte Spring 2014 Cal Poly, Team 6-5, Forte Spring 2014 的会员
CPSU-FORTE-S14S6G5
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 706
