跳转到主内容
Cyber-Shot DSC-H55 SD Card Replacement
  1. Cyber-Shot DSC-H55 SD Card Replacement, Finding where the SD slot is located: 步骤 1 中的图像 1,2 Cyber-Shot DSC-H55 SD Card Replacement, Finding where the SD slot is located: 步骤 1 中的图像 2,2
    • The SD slot is located within the battery compartment.
    • The battery compartment is located at the bottom of the camera. If you place the camera upside down with the lens facing you, you will see an arrow with the word "OPEN" under it.
  2. Cyber-Shot DSC-H55 SD Card Replacement, Removing an existing SD card: 步骤 2 中的图像 1,2 Cyber-Shot DSC-H55 SD Card Replacement, Removing an existing SD card: 步骤 2 中的图像 2,2
    • Place your thumb on the arrow and while placing some pressure, slide to the right and lift. The battery compartment will be exposed.
    • Once you have the battery compartment open push on the existing SD card and it will pop up.
  3. Cyber-Shot DSC-H55 SD Card Replacement, Inserting a new SD card: 步骤 3 中的图像 1,2 Cyber-Shot DSC-H55 SD Card Replacement, Inserting a new SD card: 步骤 3 中的图像 2,2
    • When you look inside the battery compartment you will see a slot with the words "PUSH IN/OUT" next to it. This is where the SD card belongs.
    • First make sure the slot does not already have an SD card in it.
    • Grab the SD card you want to insert, making sure it is an SD Pro Duo card, slide it into the slot and push.
结论
Jazmin Young
于01/21/15注册
608 声望
创作了5篇指南
团队
USF Tampa, Team 6-2, Brown Winter 2015 USF Tampa, Team 6-2, Brown Winter 2015 的会员
USFT-BROWN-W15S6G2
3 名成员
创作了6篇指南
2条评论
How much SD card memory will this camera accept? Can I step up to a 64 SD card?
Timothy Conrad - 回复
Can I use a 64 SD card in the Sony Cybershot, H55, camera?
Timothy Conrad - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 1,838
