跳转到主内容
Curtain Rail Clipper Replacement
你所需要的
  1. Curtain Rail Clipper Replacement, Rail Clipper: 步骤 1 中的图像 1,3 Curtain Rail Clipper Replacement, Rail Clipper: 步骤 1 中的图像 2,3 Curtain Rail Clipper Replacement, Rail Clipper: 步骤 1 中的图像 3,3
    • Unhook the curtain hooks and move your curtain aside for working space.
  2. Curtain Rail Clipper Replacement: 步骤 2 中的图像 1,3 Curtain Rail Clipper Replacement: 步骤 2 中的图像 2,3 Curtain Rail Clipper Replacement: 步骤 2 中的图像 3,3
    • Using a Square #0 Screwdriver, unscrew the faulty curtain clipper from the wall in a counter clockwise motion.
  3. Curtain Rail Clipper Replacement: 步骤 3 中的图像 1,3 Curtain Rail Clipper Replacement: 步骤 3 中的图像 2,3 Curtain Rail Clipper Replacement: 步骤 3 中的图像 3,3
    • Unscrew the connecting piece of the curtain clipper using the Square #0 screwdriver.
    • Remove the curtain clipper from the wall and the curtain rail.
  4. Curtain Rail Clipper Replacement: 步骤 4 中的图像 1,2 Curtain Rail Clipper Replacement: 步骤 4 中的图像 2,2
    • Position the new curtain clipper directly over the opening the faulty clipper was installed in.
    • Screw in the new curtain clipper using the Square #0 screwdriver and 40 mm square head screw into the wall.
    • Make sure you are screwing the clipper into the preexisting hole in the wall left by the old hangar. If not you may cause damage to your wall and are mounting the clipper incorrectly.
  5. Curtain Rail Clipper Replacement: 步骤 5 中的图像 1,3 Curtain Rail Clipper Replacement: 步骤 5 中的图像 2,3 Curtain Rail Clipper Replacement: 步骤 5 中的图像 3,3
    • Align the connecting piece of the curtain clipper to the clipper as well as the curtain rail.
    • Screw the connecting piece to the clipper and curtain rail until fastened securely using the Square #0 screwdriver and the 4 mm square head screw.
  6. Curtain Rail Clipper Replacement: 步骤 6 中的图像 1,2 Curtain Rail Clipper Replacement: 步骤 6 中的图像 2,2
    • Hook the curtain up when the clipper is fastened to ensure it holds firmly.
结论
hakim
于01/30/21注册
133 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 508
