跳转到主内容
Cuisinart Velocity Ultra Trio Blender Clutch Replacement
你所需要的
  1. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Find and remove four screws on bottom: 步骤 1 中的图像 1,2 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Find and remove four screws on bottom: 步骤 1 中的图像 2,2
    • You will need to pull out the back rubber feet to get at the screws.
  2. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove base from Blender: 步骤 2 中的图像 1,1
    • Remove base and release power cord.
  3. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove plastic support: 步骤 3 中的图像 1,1
    • Remove plastic guard and make note of the way it fits.
  4. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove motor screws: 步骤 4 中的图像 1,2 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove motor screws: 步骤 4 中的图像 2,2
    • Remove Back two motor screws
    • Remove front two motor screws
  5. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove the clutch from the motor: 步骤 5 中的图像 1,3 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove the clutch from the motor: 步骤 5 中的图像 2,3 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove the clutch from the motor: 步骤 5 中的图像 3,3
    • To remove the clutch you will need to use the flat head screw driver and twist the clutch clockwise as the thread to tighten it are reverse threaded.
    • The clutch could be worn out and not be gripping the screw and might need to be pulled off.
    • *This might be a difficult step as you are still connected to the top. If you want to try a bit of heat to melt the clutch plastic might be a solution.
  6. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove screw from end of motor: 步骤 6 中的图像 1,3 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove screw from end of motor: 步骤 6 中的图像 2,3 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove screw from end of motor: 步骤 6 中的图像 3,3
    • If the clutch didn't come off in one piece and you need to remove the nut. You will need to turn it clockwise as it is reverse threaded.
    • Using vise grips helped hold onto the nut while you can use a screw driver to turn clockwise or hold the plastic fans blades. * Because to not break a blade off as it will cause the motor to be off balance.
  7. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Insert motor and tighten: 步骤 7 中的图像 1,3 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Insert motor and tighten: 步骤 7 中的图像 2,3 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Insert motor and tighten: 步骤 7 中的图像 3,3
    • Make sure to not lose the washer.
    • Move the rubber seal to the top so you won't get any leaks into the blender.
    • Replace the four washers.
    • Replace motor and tighten four screws.
  8. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Connect new clutch to motor: 步骤 8 中的图像 1,1
    • Turn on side.
    • Make sure washer and rubber seal are in the correct position.
    • Tighten clutch by turn counter clockwise as it is reverse threaded.
    • * You don't need to over tighten as the use of the blender will cause the clutch to tighten.
  9. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Insert plastic guard support: 步骤 9 中的图像 1,1
    • Insert the correct side up.
  10. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Connect power cord and base: 步骤 10 中的图像 1,2 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Connect power cord and base: 步骤 10 中的图像 2,2
    • Connect power cord to base and tighten.
    • Tighten four screws and insert rubber feet.
    • Test blender and enjoy!
结论
Brendan
于12/14/22注册
181 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 50
总计 1,395
