跳转到主内容
Cuisinart TOA-60FR Function Switch Replacement
你所需要的
  1. Cuisinart TOA-60FR Function Switch Replacement, Outside removal: 步骤 1 中的图像 1,1
    • Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
  2. Cuisinart TOA-60FR Function Switch Replacement: 步骤 2 中的图像 1,2 Cuisinart TOA-60FR Function Switch Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
    • Pull off the back panel.
  3. Cuisinart TOA-60FR Function Switch Replacement: 步骤 3 中的图像 1,3 Cuisinart TOA-60FR Function Switch Replacement: 步骤 3 中的图像 2,3 Cuisinart TOA-60FR Function Switch Replacement: 步骤 3 中的图像 3,3
    • Flip the oven upside down.
    • Use a spudger to pull out the grey stoppers.
    • Use a Phillips #1 screwdriver to remove all three 11 mm screws.
  4. Cuisinart TOA-60FR Function Switch Replacement: 步骤 4 中的图像 1,2 Cuisinart TOA-60FR Function Switch Replacement: 步骤 4 中的图像 2,2
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
  5. Cuisinart TOA-60FR Function Switch Replacement: 步骤 5 中的图像 1,3 Cuisinart TOA-60FR Function Switch Replacement: 步骤 5 中的图像 2,3 Cuisinart TOA-60FR Function Switch Replacement: 步骤 5 中的图像 3,3
    • Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
  6. Cuisinart TOA-60FR Function Switch Replacement, Function Switch: 步骤 6 中的图像 1,3 Cuisinart TOA-60FR Function Switch Replacement, Function Switch: 步骤 6 中的图像 2,3 Cuisinart TOA-60FR Function Switch Replacement, Function Switch: 步骤 6 中的图像 3,3
    • Inside of the device locate the function switch and remove the indicated screws (4.97mm).
  7. Cuisinart TOA-60FR Function Switch Replacement: 步骤 7 中的图像 1,1
    • Unclip all connections.
  8. Cuisinart TOA-60FR Function Switch Replacement: 步骤 8 中的图像 1,3 Cuisinart TOA-60FR Function Switch Replacement: 步骤 8 中的图像 2,3 Cuisinart TOA-60FR Function Switch Replacement: 步骤 8 中的图像 3,3
    • Rotate function knob to broil so plastic tab is visible when looking from the inside between the switch and control panel. Use screwdriver to push tab down and pull knob out from front side.
    • Remove 2 screws revealed under the front knob
结论
7等其他人完成本指南。
14指南评论
Anyone have a source for a replacement switch?
Josh - 回复
I ordered mine on Amazon
Martin Baumeister -
Big thanks for providing these instructions! It worked!
Martin Baumeister - 回复
Thanks for the guide. Saved me the headache of having to find a new toaster oven and paying for it.
For those needing it, the part I ordered and used is part model number FZ31-9E (11 pins 7 positions) from amazon.
The switch will also have letters and numbers corresponding to the orientation as in step 6 so keep an eye out for that!
Adam Nguyen - 回复
Part of Step 8...Difficult to understand picture how to remove knob on switch? i did follow up instruction that i didn't clear instruction if you have any video how to remove knob from panel switch?
Thanks Todd
Todd Bouma - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 57
过去 30 天: 285
总计 5,223
