跳转到主内容
Cuisinart Smart Stick CSB-75 Power Switch Board Replacement
你所需要的
  1. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement, Power Switch Board: 步骤 1 中的图像 1,3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement, Power Switch Board: 步骤 1 中的图像 2,3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement, Power Switch Board: 步骤 1 中的图像 3,3
    • Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
    • After prying these off, the screws will be exposed.
  2. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: 步骤 2 中的图像 1,2 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: 步骤 2 中的图像 2,2
    • Remove three 13.3 mm Phillips PH#2 screws.
  3. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: 步骤 3 中的图像 1,3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: 步骤 3 中的图像 2,3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: 步骤 3 中的图像 3,3
    • Pry open Cuisinart using a plastic opening tool.
    • The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Make sure to pry open near the clips of the smart stick for easy opening.
  4. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: 步骤 4 中的图像 1,3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: 步骤 4 中的图像 2,3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: 步骤 4 中的图像 3,3
    • Unscrew the 4 screws on the inside.
    • Remove 2 13.3mm Phillips PH#2 screws.
    • Remove 2 17.5 mm Phillips PH#2 screws.
    • Unscrewing these screws will isolate the switch board.
  5. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: 步骤 5 中的图像 1,2 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: 步骤 5 中的图像 2,2
    • Refer to these steps on Soldering to replace the switch board in the smart stick.
    • Be careful when soldering. Metal components will become very hot.
结论
另外一个人完成了本指南。
Jordan Robinson
于09/02/15注册
557 声望
创作了4篇指南
团队
USF Tampa, Team 16-2, Wollert Fall 2015 USF Tampa, Team 16-2, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 27
过去 30 天: 84
总计 1,498
