简介
This guide will teach you how to replace the motor inside your Cuisinart Smart Stick. If power is not being supplied to the Smart Stick, the motor could be unresponsive.
你所需要的
Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
After prying these off, the screws will be exposed.
6等其他人完成本指南。
5条评论
where can I find the coupling from the motor to the shaft?
Thanks for this tutorial Jordan! I have the same question than Alejandro Serra though, I was wondering if someone know where we can find the plastic coupling between the motor shaft and the kitchen tool. Mine is striped and I can’t find this specific part. This is a shame since the motor is in perfect shape so just a little plastic part is ruining the whole device. If anyone has see this part or if you have a way to fix a stripped one, please let me know!
Hello, did u ever end up finding this same piece of plastic you were looking for? Turns out mine is stripped too and i need one
Does anyone know where to find small replacement parts for this? I'm specifically looking for the white (I think nylon) cylindrical piece which is held by friction to the motor shaft, and which has teeth on the inside to engage with the blade shaft.
Still nothing?
