跳转到主内容
Cuisinart Griddler GR-4N Cooking Surfaces Replacement
你所需要的
  1. Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: 步骤 1 中的图像 1,2 Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: 步骤 1 中的图像 2,2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: 步骤 2 中的图像 1,1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: 步骤 3 中的图像 1,1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: 步骤 4 中的图像 1,1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: 步骤 5 中的图像 1,2 Cuisinart Griddler GR-4N Cooking Surfaces Replacement: 步骤 5 中的图像 2,2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
结论
另外一个人完成了本指南。
Kayla Londono
于04/15/16注册
632 声望
创作了4篇指南
团队
Cal Poly, Team 1-12, Maness Spring 2016 Cal Poly, Team 1-12, Maness Spring 2016 的会员
CPSU-MANESS-S16S1G12
4 名成员
创作了6篇指南
一条评论
The 'cooking plates' on my unit always fall off. I tried bending the tabs to make it tighter - did not help. Any ideas?
M S - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 32
总计 4,048
