跳转到主内容
Cuisinart Griddler GR- 4N LED Light Replacement
你所需要的
  1. Cuisinart Griddler GR- 4N LED Light  Replacement, Cooking Surfaces: 步骤 1 中的图像 1,2 Cuisinart Griddler GR- 4N LED Light  Replacement, Cooking Surfaces: 步骤 1 中的图像 2,2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR- 4N LED Light  Replacement: 步骤 2 中的图像 1,1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR- 4N LED Light  Replacement: 步骤 3 中的图像 1,1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR- 4N LED Light  Replacement: 步骤 4 中的图像 1,1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR- 4N LED Light  Replacement: 步骤 5 中的图像 1,2 Cuisinart Griddler GR- 4N LED Light  Replacement: 步骤 5 中的图像 2,2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  6. Cuisinart Griddler GR- 4N LED Light  Replacement, Cuisinart Griddler GR- 4N Disassembly: 步骤 6 中的图像 1,1
    • Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
    • Move the circuit board to the side so it is out of the way.
  7. Cuisinart Griddler GR- 4N LED Light  Replacement: 步骤 7 中的图像 1,1
    • Remove the two 6 mm Phillips #2 screws that secure the white plastic LED holder.
  8. Cuisinart Griddler GR- 4N LED Light  Replacement, LED Light: 步骤 8 中的图像 1,2 Cuisinart Griddler GR- 4N LED Light  Replacement, LED Light: 步骤 8 中的图像 2,2
    • Cut the zip ties which hold the LED lights in place with scissors/knife.
  9. Cuisinart Griddler GR- 4N LED Light  Replacement: 步骤 9 中的图像 1,2 Cuisinart Griddler GR- 4N LED Light  Replacement: 步骤 9 中的图像 2,2
    • Slide back black plastic covers and cut the two wires connected to the LED with a pair of scissors.
    • The LED bulb should now be free to remove. In order to replace bulb you must solder the new LED into the existing wires.
    • Upon soldering the LED will need to be zip tied back in place.
结论
2等其他人完成本指南。
Kayla Londono
于04/15/16注册
632 声望
创作了4篇指南
团队
Cal Poly, Team 1-12, Maness Spring 2016 Cal Poly, Team 1-12, Maness Spring 2016 的会员
CPSU-MANESS-S16S1G12
4 名成员
创作了6篇指南
4条评论
Hai
is there any body can come home and help me
or any place I can send my machine and repair
regds
Leela Manilal
Raghavan Manilal - 回复
any tips on how to fix a broken thermostat?
Jean-Michel Léon - 回复
Will any green LED work? Or does it have to be a particular voltage?
Bob Mounger - 回复
How do I get the heating element off? It seems pretty securely connected via the red and white wires connected to the machine. Is there an easy way to disassemble this part? I honestly just want to clean the baked on grease on the pans but I’ve got to remove the heating element in order to do that. Any advice would be most appreciated. Thanks!
Katie Hoppmann - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 20
总计 1,260
