跳转到主内容
Cuisinart Griddler GR- 4N Knobs Replacement
你所需要的
  1. Cuisinart Griddler GR- 4N Knobs Replacement, Cooking Surfaces: 步骤 1 中的图像 1,2 Cuisinart Griddler GR- 4N Knobs Replacement, Cooking Surfaces: 步骤 1 中的图像 2,2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR- 4N Knobs Replacement: 步骤 2 中的图像 1,1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR- 4N Knobs Replacement: 步骤 3 中的图像 1,1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR- 4N Knobs Replacement: 步骤 4 中的图像 1,1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR- 4N Knobs Replacement: 步骤 5 中的图像 1,2 Cuisinart Griddler GR- 4N Knobs Replacement: 步骤 5 中的图像 2,2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  6. Cuisinart Griddler GR- 4N Knobs Replacement, Cuisinart Griddler GR- 4N Disassembly: 步骤 6 中的图像 1,1
    • Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
    • Move the circuit board to the side so it is out of the way.
  7. Cuisinart Griddler GR- 4N Knobs Replacement: 步骤 7 中的图像 1,1
    • Remove the two 6 mm Phillips #2 screws that secure the white plastic LED holder.
  8. Cuisinart Griddler GR- 4N Knobs Replacement, Knobs: 步骤 8 中的图像 1,1
    • Pinch back plastic arms on knob while pulling out the knob.
  9. Cuisinart Griddler GR- 4N Knobs Replacement: 步骤 9 中的图像 1,1
    • Pop the new knob back into the hole and the repair is complete.
结论
2等其他人完成本指南。
Kayla Londono
于04/15/16注册
632 声望
创作了4篇指南
团队
Cal Poly, Team 1-12, Maness Spring 2016 Cal Poly, Team 1-12, Maness Spring 2016 的会员
CPSU-MANESS-S16S1G12
4 名成员
创作了6篇指南
14条评论
Where do you find the replacement knobs?
Chris Reece - 回复
Wish I knew! I need two knobs. Are their universal knobs out there that can be substituted?
sfk -
im in same boat can't find the dials/knobs- 2 of mine are broken and useless
Mark Stevens - 回复
Cuisinart offers NO help. I will have to toss out a $100.00 unit over a $2.00 part.
Nick - 回复
I have several cuisinart appliances. I won't ever buy another. I need one replacement knob, the best they can do is 20 percent off on a new griddler . I can get that from bed bath and beyond. Thanks cuisinart, finding new brands. Cuisinart is dead to me.
allen brathwaite - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 69
总计 10,093
