简介
If your cooking surface isn't turning on or is being pushed up you may need to replace a spring, a process which will be explained in this guide.
你所需要的
Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
The aligned parts will allow the cooking surfaces to work properly.
2等其他人完成本指南。
