简介
This guide teaches the user how to replace the power cable in your Cuisinart DLC-8F. The removal of the power cable first requires the removal of the bottom hood and all of this can be done with just a Phillips #2 screwdriver. This is an easy process and should only take about 10 minutes.
你所需要的
Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
2等其他人完成本指南。
一条评论
So you pull apart the wires of the power cable and then what? Instructions seem incomplete.
nancimoll1 - 回复
