跳转到主内容
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement
你所需要的
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement, Internal Wiring: 步骤 1 中的图像 1,1
    • Remove the four screws from the bottom of the processor with a Philips Screwdriver.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom casing of the processor.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: 步骤 3 中的图像 1,1
    • If any wires are frayed, cut them off where they are connected by wire nuts.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: 步骤 4 中的图像 1,1
    • Detach the wire nut from the other connected wires.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: 步骤 5 中的图像 1,1
    • Replace the bad wire with a new one of the same gauge.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: 步骤 6 中的图像 1,1
    • Strip the new wire to the same length as the other wires and connect them to a wire nut.
结论
另外一个人完成了本指南。
Riley Carns
于04/02/15注册
279 声望
创作了2篇指南
团队
Cal Poly, Team 24-1, Lancaster Winter 2015 Cal Poly, Team 24-1, Lancaster Winter 2015 的会员
CPSU-LANCASTER-W15S24G1
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,002
