跳转到主内容
Cuisinart DFP-14BCN Buttons Replacement
你所需要的
  1. Cuisinart DFP-14BCN Buttons Replacement, Bowl: 步骤 1 中的图像 1,3 Cuisinart DFP-14BCN Buttons Replacement, Bowl: 步骤 1 中的图像 2,3 Cuisinart DFP-14BCN Buttons Replacement, Bowl: 步骤 1 中的图像 3,3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Buttons Replacement: 步骤 3 中的图像 1,3 Cuisinart DFP-14BCN Buttons Replacement: 步骤 3 中的图像 2,3 Cuisinart DFP-14BCN Buttons Replacement: 步骤 3 中的图像 3,3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Buttons Replacement: 步骤 4 中的图像 1,1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Buttons Replacement: 步骤 5 中的图像 1,3 Cuisinart DFP-14BCN Buttons Replacement: 步骤 5 中的图像 2,3 Cuisinart DFP-14BCN Buttons Replacement: 步骤 5 中的图像 3,3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Buttons Replacement, Back Casing: 步骤 6 中的图像 1,2 Cuisinart DFP-14BCN Buttons Replacement, Back Casing: 步骤 6 中的图像 2,2
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Buttons Replacement: 步骤 7 中的图像 1,2 Cuisinart DFP-14BCN Buttons Replacement: 步骤 7 中的图像 2,2
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Buttons Replacement: 步骤 8 中的图像 1,3 Cuisinart DFP-14BCN Buttons Replacement: 步骤 8 中的图像 2,3 Cuisinart DFP-14BCN Buttons Replacement: 步骤 8 中的图像 3,3
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Buttons Replacement: 步骤 9 中的图像 1,2 Cuisinart DFP-14BCN Buttons Replacement: 步骤 9 中的图像 2,2
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Buttons Replacement, Buttons: 步骤 10 中的图像 1,3 Cuisinart DFP-14BCN Buttons Replacement, Buttons: 步骤 10 中的图像 2,3 Cuisinart DFP-14BCN Buttons Replacement, Buttons: 步骤 10 中的图像 3,3
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Buttons Replacement: 步骤 11 中的图像 1,2 Cuisinart DFP-14BCN Buttons Replacement: 步骤 11 中的图像 2,2
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Buttons Replacement: 步骤 12 中的图像 1,1
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Buttons Replacement: 步骤 13 中的图像 1,3 Cuisinart DFP-14BCN Buttons Replacement: 步骤 13 中的图像 2,3 Cuisinart DFP-14BCN Buttons Replacement: 步骤 13 中的图像 3,3
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
结论
另外一个人完成了本指南。
Sonya Dick
于10/05/16注册
352 声望
创作了3篇指南
团队
Cal Poly, Team 10-3, Livingston Fall 2016 Cal Poly, Team 10-3, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S10G3
3 名成员
创作了7篇指南
一条评论
Is there a source for replacing the button assembly?
BadMahoney - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 15
总计 1,099
