跳转到主内容
Cuisinart DCC-3200 Hot Plate Replacement
你所需要的
  1. Cuisinart DCC-3200 Hot Plate Replacement, Hot Plate: 步骤 1 中的图像 1,1
    • Unplug the device and flip it over so the bottom is facing upwards.
    • Remove the four screws.
    • Remove the bottom panel.
  2. Cuisinart DCC-3200 Hot Plate Replacement: 步骤 2 中的图像 1,1
    • Remove the two screws from the silver brace.
  3. Cuisinart DCC-3200 Hot Plate Replacement: 步骤 3 中的图像 1,2 Cuisinart DCC-3200 Hot Plate Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to wedge the red tube off of the metal.
    • Repeat this for the other side of the silver pipe deeper in the device.
  4. Cuisinart DCC-3200 Hot Plate Replacement: 步骤 4 中的图像 1,1
    • Pick up the middle pipe and slide the hot plate out of its area.
    • Apply new thermal paste to the hot plate.
结论
2等其他人完成本指南。
Hamad Khan
于03/04/16注册
385 声望
创作了3篇指南
团队
UMass Dartmouth, Team 8-3, Botvin Spring 2016 UMass Dartmouth, Team 8-3, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G3
3 名成员
创作了3篇指南
5条评论
Where can one purchase the burner plate?
john Vet - 回复
Same question as John Vet
Bob Stimson - 回复
Did anyone ever get a response as to where a replacement could be purchased?
Joe Lubrant -
Did response provide required info?
Joe Lubrant - 回复
Same question: where can we purchase the burner plate?
Cresny - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 108
总计 4,855
