跳转到主内容
Cuisinart DCC-1200 Coffee Carafe Handle Replacement
你所需要的
  1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: 步骤 1 中的图像 1,3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: 步骤 1 中的图像 2,3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: 步骤 1 中的图像 3,3
    • Wedge the metal spudger between the plug and the handle.
    • Carefully pry the plug with the metal spudger by applying pressure around the plug.
    • Too much pressure and prying can damage the plug.
  2. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 步骤 2 中的图像 1,2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 步骤 2 中的图像 2,2
    • Use the bit driver with the Phillips PH1 bit to remove the 27 millimeter long screw in the base of the handle.
  3. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 步骤 3 中的图像 1,1
    • Lift up on and remove the lid from the carafe.
  4. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 步骤 4 中的图像 1,2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 步骤 4 中的图像 2,2
    • Position the metal spudger underneath the top cap of the handle.
    • Gently pry up to extract the upper assembly cap.
    • Pry carefully to prevent from causing aesthetic damage to upper assembly cap.
  5. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 步骤 5 中的图像 1,1
    • Use the bit driver with the Phillips PH1 to remove the 5 millimeter screw in upper assembly of handle.
    • Remove handle by lifting straight up.
结论
3等其他人完成本指南。
Austin Wheaton
于02/15/18注册
861 声望
创作了4篇指南
团队
UW Stout, Team S8-G1, Ogden Spring 2018 UW Stout, Team S8-G1, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G1
4 名成员
创作了5篇指南
一条评论
I needed this guide after my spouse put the carafe in the dishwasher and the handle sloshed no matter how much I shook it. It turns out water is easily trapped under the top cap; even though there's a drain hole into the handle, it doesn't seem to want to drain. I've wiped it off and left it to dry completely before reassembling it.
Max - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 33
总计 3,730
