跳转到主内容
Cuisinart DCC-1200 Hose Replacement
你所需要的
  1. Cuisinart DCC-1200  Hose Replacement, Water Hoses: 步骤 1 中的图像 1,3 Cuisinart DCC-1200  Hose Replacement, Water Hoses: 步骤 1 中的图像 2,3 Cuisinart DCC-1200  Hose Replacement, Water Hoses: 步骤 1 中的图像 3,3
    • Flip the coffee maker over so the bottom is facing upwards.
    • Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
    • Lift the bottom cover off the bottom of the coffee maker.
  2. Cuisinart DCC-1200  Hose Replacement: 步骤 2 中的图像 1,2 Cuisinart DCC-1200  Hose Replacement: 步骤 2 中的图像 2,2
    • Gently squeeze the hose clamps together and begin moving the metal clamp away from the heating element.
  3. Cuisinart DCC-1200  Hose Replacement: 步骤 3 中的图像 1,3 Cuisinart DCC-1200  Hose Replacement: 步骤 3 中的图像 2,3 Cuisinart DCC-1200  Hose Replacement: 步骤 3 中的图像 3,3
    • Gently pull on the loose hose to remove it from the heating element.
  4. Cuisinart DCC-1200  Hose Replacement: 步骤 4 中的图像 1,3 Cuisinart DCC-1200  Hose Replacement: 步骤 4 中的图像 2,3 Cuisinart DCC-1200  Hose Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Squeeze the clamp with tweezers on the opposite end of the hose from the one you already removed.
    • Once the clamp is free, gently pull upwards on the hose to remove it.
    • Replace the disconnected hose with a new functioning hose.
结论
3等其他人完成本指南。
Austin Wheaton
于02/15/18注册
861 声望
创作了4篇指南
团队
UW Stout, Team S8-G1, Ogden Spring 2018 UW Stout, Team S8-G1, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G1
4 名成员
创作了5篇指南
10条评论
I think this was a brand new coffee maker used for this demo. My hoses will not budge. I would guess they soften up and permanently adhere to heating element over time. Also, from other videos, there is a ball in the hose (to control direction of water.) Not sure if you can replace with any old hose.
George Heynen - 回复
Oh yeah that really helped, why not tell us where you got the hose or what type it is?
Silicon Durometer 50 or 70 or is it something else, totally useless site, waste of time.
Ronald Swapp - 回复
Wish someone would answer this good question…
kenzenmaster -
Where to get, and what kind of replacement hoses ??? Do you need a new ball in little filter , or do you need the filter at all ???
kenzenmaster - 回复
https://www.amazon.com/gp/product/B003SY... this is where I ordered red hose from. $5.69 for a foot.
Mike carey - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 30
过去 30 天: 158
总计 15,430
