跳转到主内容
Cuisinart DCC-1100 Hot Plate Replacement
你所需要的
  1. Cuisinart DCC-1100 Hot Plate Replacement, Hot Plate: 步骤 1 中的图像 1,1
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Hot Plate Replacement: 步骤 2 中的图像 1,1
    • Remove the coffee pot and place the coffee maker upside down.
  3. Cuisinart DCC-1100 Hot Plate Replacement: 步骤 3 中的图像 1,1
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
  4. Cuisinart DCC-1100 Hot Plate Replacement: 步骤 4 中的图像 1,1
    • Remove the bottom panel.
  5. Cuisinart DCC-1100 Hot Plate Replacement: 步骤 5 中的图像 1,1
    • Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
  6. Cuisinart DCC-1100 Hot Plate Replacement: 步骤 6 中的图像 1,1
    • Remove the retaining bracket and allow it to hang off of the heating element.
  7. Cuisinart DCC-1100 Hot Plate Replacement: 步骤 7 中的图像 1,1
    • Remove the hot plate from the heating element.
    • New thermal paste should be applied at time of installation.
结论
4等其他人完成本指南。
Josh Harvey
于01/25/18注册
889 声望
创作了4篇指南
团队
USF Tampa, Team S20-G4, Passmore Spring 2018 USF Tampa, Team S20-G4, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G4
4 名成员
创作了7篇指南
13条评论
thank you for this informative display.
I have broken many expensive glass carafs for my cuisinart coffeemaker and finally purchased a cuisinart thermal caraf.
I do not need the hotplate to heat, so what do I do to stop the heating process?
I imagine I would need to remove one of the attached lines to the heating element, yes?
Thanks.
Luciano
luciano1213@msn.com
Luciano Muzzatti - 回复
Hi, Thanks for sharing this information. I have an older Krups coffee maker that still works great but the hot plate is warn. I cannot seem to find a replacement plate for any Krups coffee maker models. Any suggestions? Thanks!
Paulette Paglia - 回复
Josh
where do I buy the replacement hot plate?? I have the sis 15 coffeemaker and I have googled all over the place?? Thank u
linkev428 - 回复
Yes, where do you buy the part??
Kathy Johnston - 回复
Yes my question is where do you get the new hot plate? Any direction appreciated.
DougB - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 6,167
