你所需要的
Turn the device upside down.
Remove all four rubber feet by prying them out using the metal spudger.
Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
Remove the 2 black, yellow, and red wires from circuit board by push down on the tab to release and then pull up.
即将完成!
结论
