跳转到主内容
Cuisinart CHW-12 Power Cord Replacement
你所需要的
  1. Cuisinart CHW-12 Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,2 Cuisinart CHW-12 Power Cord Replacement, Power Cord: 步骤 1 中的图像 2,2
    • Unplug the coffee-maker from the power source.
    • Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
  2. Cuisinart CHW-12 Power Cord Replacement: 步骤 2 中的图像 1,2 Cuisinart CHW-12 Power Cord Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the two rubber feet marked within the provided pictures.
    • Remove both 8mm Phillips head screws found within the holes where the feet were just removed.
  3. Cuisinart CHW-12 Power Cord Replacement: 步骤 3 中的图像 1,3 Cuisinart CHW-12 Power Cord Replacement: 步骤 3 中的图像 2,3 Cuisinart CHW-12 Power Cord Replacement: 步骤 3 中的图像 3,3
    • Carefully pull the cover off the bottom of the coffee maker. This will give you access to the inside of the coffee maker.
    • Pull the gray ribbon cable strait out of the black containment box.
  4. Cuisinart CHW-12 Power Cord Replacement: 步骤 4 中的图像 1,3 Cuisinart CHW-12 Power Cord Replacement: 步骤 4 中的图像 2,3 Cuisinart CHW-12 Power Cord Replacement: 步骤 4 中的图像 3,3
    • Locate the Phillips head screws holding the highlighted plastic shield in place.
    • Remove the two 14mm screws with a Phillips head screwdriver.
    • Carefully slide the shield out of place along the power cord and set it aside.
  5. Cuisinart CHW-12 Power Cord Replacement: 步骤 5 中的图像 1,3 Cuisinart CHW-12 Power Cord Replacement: 步骤 5 中的图像 2,3 Cuisinart CHW-12 Power Cord Replacement: 步骤 5 中的图像 3,3
    • Remove the two 14mm Phillips head screws securing the plastic containment box.
    • Pull the plastic containment box straight out of the coffee maker.
  6. Cuisinart CHW-12 Power Cord Replacement: 步骤 6 中的图像 1,2 Cuisinart CHW-12 Power Cord Replacement: 步骤 6 中的图像 2,2
    • Remove the four 11mm Phillips head screws in each corner of the plastic containment box.
    • Pull the top from the plastic housing.
  7. Cuisinart CHW-12 Power Cord Replacement: 步骤 7 中的图像 1,3 Cuisinart CHW-12 Power Cord Replacement: 步骤 7 中的图像 2,3 Cuisinart CHW-12 Power Cord Replacement: 步骤 7 中的图像 3,3
    • Pull the circuit board out of the containment box.
    • Locate the power cable connection point on the circuit board.
    • Desolder the power cable wires connected to the board.
    • Solder iron can cause burns if used improperly.
    • Replace the power cable with the corresponding wires of the new power cable.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 36
总计 1,847
