跳转到主内容
Crosley CR8005A Volume Knob Replacement
你所需要的
  1. Crosley CR8005A Volume Knob Replacement, Volume Knob: 步骤 1 中的图像 1,1
    • Identify the volume knob.
    • It is in the bottom-right corner of the turntable, just under the power light.
  2. Crosley CR8005A Volume Knob Replacement: 步骤 2 中的图像 1,2 Crosley CR8005A Volume Knob Replacement: 步骤 2 中的图像 2,2
    • Make sure that the power is off.
    • Turn the volume knob counterclockwise as far as possible.
    • Unplug the power cord.
    • The power light should be off. If the light is glowing red, wait until the light goes out.
  3. Crosley CR8005A Volume Knob Replacement: 步骤 3 中的图像 1,1
    • Slip the plastic opening tool between the knob and the turntable.
    • In place of an opening tool, a spudger will also work.
  4. Crosley CR8005A Volume Knob Replacement: 步骤 4 中的图像 1,2 Crosley CR8005A Volume Knob Replacement: 步骤 4 中的图像 2,2
    • Use the opening tool to pry open the knob.
    • To prevent the knob from flying off, you can keep one hand lightly on top of the knob for security. There may be an audible click as the knob comes off.
  5. Crosley CR8005A Volume Knob Replacement: 步骤 5 中的图像 1,1
    • The knob should now be free to inspect, customize, or replace.
结论
To put the knob back on, push the knob directly down onto its peg.
另外一个人完成了本指南。
2条评论
Hi, how to change the actual know (not the plastic cover)?
As mine is faulty and I could use some help please haha
Lucas Robin - 回复
Digi-key part # similar to PTD908-1215K-B203-ND.
Scott Whitehill - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 41
总计 1,962
