跳转到主内容
Crosley CR8005A Belt Replacement
你所需要的
  1. Crosley CR8005A Belt Replacement, Belt: 步骤 1 中的图像 1,1
    • Remove the slipmat and locate the small, round clip which holds the turntable platter to the turntable.
    • Insert the iFixit opening tool between the spindle and the clip and pry off the clip.
    • The clip does not need to be replaced and might already be missing.
  2. Crosley CR8005A Belt Replacement: 步骤 2 中的图像 1,1
    • After removing the clip, lift the turntable platter off the chrome spindle on the turntable base. The band connects the platter to the turntable base and will likely fall off in this process.
    • There will be some lubricant on the band and the metal prong on the turntable base. Leave this lubricant as is.
  3. Crosley CR8005A Belt Replacement: 步骤 3 中的图像 1,1
    • Turn the platter over so that you are looking at the underside.
    • Stretch the new band around the raised, internal circle and loop the band over the raised prong. This will create a teardrop shape with your new band.
    • Try not to over-stretch the new band or you will need to replace it too.
  4. Crosley CR8005A Belt Replacement: 步骤 4 中的图像 1,1
    • Turn the platter back over and place it on the spindle.
    • Spin the platter 2 times clockwise to unloop the band from the raised prong on the platter and to loop it around the raised prong on the turntable base. This allows the circular motion of the motor to spin the band and the turntable platter.
    • You may replace the round clip at this point though it is not important to the sound quality of the turntable.
结论
Now, spin some tunes and enjoy your improved sound!
4等其他人完成本指南。
Ramie Bell
于10/30/19注册
249 声望
撰写一个指南
一条评论
what to do if you cannot lift up the platter in step 2.
Priyanka Baghaie - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 37
过去 30 天: 182
总计 12,868
