跳转到主内容
Crosley CR704 Speaker Replacement
你所需要的
  1. Crosley CR704 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
  2. Crosley CR704 Speaker Replacement: 步骤 2 中的图像 1,1
    • Gently remove the back panel of the device being careful not to unplug any internal wires.
  3. Crosley CR704 Speaker Replacement: 步骤 3 中的图像 1,1
    • Using your Phillips head screwdriver, remove the 4 brass speaker screws.
    • Be careful to not remove the speaker housing screws, which surround the speaker screws.
  4. Crosley CR704 Speaker Replacement: 步骤 4 中的图像 1,1
    • Carefully pull the wires out of their connections from the back of the speaker.
    • Don't forget which wire goes with which connection!
结论
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
另外一个人完成了本指南。
MarkAnthony
于09/22/13注册
772 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S1G4
3 名成员
创作了5篇指南
一条评论
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
ninjadaniel66 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 2,831
