跳转到主内容
简介
When everything is working as it should, the speaker produces nearly the same vibrations that the microphone originally recorded and encoded on a tape, CD or LP record.
配件
没有特定配件。
  1. Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
    • Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
  2. Gently remove the back panel of the device being careful not to unplug any internal wires.
    • Gently remove the back panel of the device being careful not to unplug any internal wires.
  3. Using your Phillips head screwdriver, remove the 4 brass speaker screws.
    • Using your Phillips head screwdriver, remove the 4 brass speaker screws.
    • Be careful to not remove the speaker housing screws, which surround the speaker screws.
  4. Carefully pull the wires out of their connections from the back of the speaker.
    • Carefully pull the wires out of their connections from the back of the speaker.
    • Don't forget which wire goes with which connection!
结论
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
另外一个人完成了本指南。
MarkAnthony
于2013年09月22日注册
637 信誉积分
创作了5篇指南
团队
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S1G4
3 名成员
创作了5篇指南
一条评论
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
ninjadaniel66 - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 26
总计 2,191
