跳转到主内容
简介
The Crosley CR704 turntable is belt driven. This means the motor that spins your records is attached to the platter via a belt.
If you can hear the motor under your turn table working, but the platter won't spin, you may need to adjust or replace your drive-belt. Follow these easy steps to do so.
配件
  1. Unplug power cable (if it's plugged in) so you don't electrocute yourself (or loved ones).
    • Unplug power cable (if it's plugged in) so you don't electrocute yourself (or loved ones).
    • Secure tone arm so it doesn't hurt itself (or you).
  2. Using a flat edge (such as a spudger or a flathead screwdriver) pry the C-clamp from the center spindle by wedging the flat edge between the spindle and the C-clamp.
    • Using a flat edge (such as a spudger or a flathead screwdriver) pry the C-clamp from the center spindle by wedging the flat edge between the spindle and the C-clamp.
    • The C-clamp may pop off unexpectedly, so be careful it doesn't fall somewhere hard to reach.
    • The C-clamp his what holds the platter in place. With it removed, you can now et under the platter.
  3. You can now lift the platter. The drive-belt will be found either around the bottom of the platter or around the motor.
    • You can now lift the platter.
    • The drive-belt will be found either around the bottom of the platter or around the motor.
    • If the drive-belt is broken it will need to be replaced. If it is loose, you can simply re-secure it.
    • To replace the belt, wrap it around the inner circle of the bottom of the platter. Then stretch the belt around one of the two pegs found near the outer edge of the bottom of the platter.
    • This will be a snug fit, so be careful not to snap the rubber belt!
    Please include a picture for this step thank you!
    Bill Payne - 回复
  4. Using your thumb as a guide, place the platter back onto the motor so that  the peg holding the drive-belt wraps around the outside of the brass motor post.
    • Using your thumb as a guide, place the platter back onto the motor so that the peg holding the drive-belt wraps around the outside of the brass motor post.
  5. Secure the platter all the way down and spin the platter clockwise until you hear a pop and feel resistance from the drive-belt catching.
    • Secure the platter all the way down and spin the platter clockwise until you hear a pop and feel resistance from the drive-belt catching.
  6. You can replace the C-clamp by shoving it back into place around the center spindle (this will require some force).
    • You can replace the C-clamp by shoving it back into place around the center spindle (this will require some force).
    • It's not necessary to replace the C-clamp unless you plan on moving the device around.
结论
Test by playing a record. We suggest "Take Five" by The Dave Brubeck Quartet.
2等其他人完成本指南。
MarkAnthony
于2013年09月22日注册
637 信誉积分
创作了5篇指南
团队
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S1G4
3 名成员
创作了5篇指南
2条评论
followed instructions multiple times—hear and see that the drive motor is spinning but platter is not— what’s wrong
Holly Shulman - 回复
The belt is fine and placed correctly but the record speed (33 and 1/3) is off. Spins too fast.
Suggestions?
Gary Sivertsen - 回复
添加评论
浏览统计数据:
过去的24小时: 7
过去的7天: 51
过去的30天: 131
总计 18,731
