简介
The Crosley CR704 turntable is belt driven. This means the motor that spins your records is attached to the platter via a belt.
If you can hear the motor under your turn table working, but the platter won't spin, you may need to adjust or replace your drive-belt. Follow these easy steps to do so.
你所需要的
Unplug power cable (if it's plugged in) so you don't electrocute yourself (or loved ones).
Secure tone arm so it doesn't hurt itself (or you).
You can now lift the platter.
If the drive-belt is broken it will need to be replaced. If it is loose, you can simply re-secure it.
To replace the belt, wrap it around the inner circle of the bottom of the platter. Then stretch the belt around one of the two pegs found near the outer edge of the bottom of the platter.
Test by playing a record. We suggest "Take Five" by The Dave Brubeck Quartet.
7等其他人完成本指南。
4条评论
followed instructions multiple times—hear and see that the drive motor is spinning but platter is not— what’s wrong
The belt is fine and placed correctly but the record speed (33 and 1/3) is off. Spins too fast.
Suggestions?
What is the size of the c-clip / c-clamp? I’d like to replace one.
Perfect! Needed to add some sewing oil to reduce squeaking, and didn't have a clue how it went back on. This helped immensely!
