简介
Bushings are the rubber components in record players. Worn or loose bushings need to be replaced. This guide shows how to replace the bushings in the Crosley CR42 Player.
你所需要的
Turn the device around so the line out port faces you.
Remove the ten 12 mm screws with the Phillips screwdriver.
即将完成!
结论
另外一个人完成了本指南。
