跳转到主内容
Crosley 33301 Front Glass Replacement
你所需要的
  1. Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: 步骤 1 中的图像 1,3 Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: 步骤 1 中的图像 2,3 Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: 步骤 1 中的图像 3,3
    • Rotate Clock till the face/or front is pointing away from you.
    • Continue on by unscrewing the 5.5 millimeter screws with your hands.
    • Once all the screws are removed, take the circular back panel off and lay it down flat on a stable surface to put back on later.
  2. Crosley 33301 Front Glass Replacement: 步骤 2 中的图像 1,2 Crosley 33301 Front Glass Replacement: 步骤 2 中的图像 2,2
    • Unscrew the two remaining screws with a PH2 bit.
    • Do not be afraid to use additional force to remove these screws. Just be careful not to break the clock!
  3. Crosley 33301 Front Glass Replacement: 步骤 3 中的图像 1,2 Crosley 33301 Front Glass Replacement: 步骤 3 中的图像 2,2
    • Remove the front part of the clock from the back frame.
    • No major force is required. The back frame should slide right off.
  4. Crosley 33301 Front Glass Replacement: 步骤 4 中的图像 1,2 Crosley 33301 Front Glass Replacement: 步骤 4 中的图像 2,2
    • You will notice that there are three small indents on alternate sides.
    • You will see small slits where the indents can slide through.
    • Twist the center counter clockwise so that the face and the back are no longer connected.
  5. Crosley 33301 Front Glass Replacement: 步骤 5 中的图像 1,2 Crosley 33301 Front Glass Replacement: 步骤 5 中的图像 2,2
    • Replace the front of the clock with your new glass face protector and settle it on the frame.
    • The glass for this clock is 10cm in diameter. It would be best to use glass that fits this measurement!
  6. Crosley 33301 Front Glass Replacement: 步骤 6 中的图像 1,3 Crosley 33301 Front Glass Replacement: 步骤 6 中的图像 2,3 Crosley 33301 Front Glass Replacement: 步骤 6 中的图像 3,3
    • Apply the clock face back on the frame, then reverse your steps. Take a step back and admire your handiwork!
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 23
总计 1,914
