简介
The belt of the Cricut Maker allows the machine to maneuver the blades and engraving tips along the desired material to produce desired patterns. If the belt is worn out or damaged, you may need to replace it.
If you find your machine will not sustain your patterns or the patterns are damaged or delayed, this replacement guide is for you!
Be sure to turn your Cricut Maker off and unplug it from the outlet before beginning this guide.
你所需要的
To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
Remove the cover from the connecting joint and set it aside.
Using your hands or an opening tool, remove the four foot pads covering four screws.
Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
Use a Phillips #1 screwdriver to remove the four 5 mm screws that attach the motor on the left side of the machine.
4等其他人完成本指南。
4指南评论
Where can I find the replace for the belt?
Wie auch meine Vorredner, würde ich gerne wissen, ob du einen Link zu einem passenden Riemen bereitstellen kannst.
Beste Grüße
No answer on where to buy 😵💫😵💫😵💫
