跳转到主内容
Creative Ziio 7" LCD Screen Replacement
你所需要的
  1. Creative Ziio 7" LCD Screen Replacement, Back Panel: 步骤 1 中的图像 1,3 Creative Ziio 7" LCD Screen Replacement, Back Panel: 步骤 1 中的图像 2,3 Creative Ziio 7" LCD Screen Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" LCD Screen Replacement, LCD Screen: 步骤 2 中的图像 1,1
    • Remove the four 3mm Philips #00 screws around the large silver battery.
  3. Creative Ziio 7" LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
  4. Creative Ziio 7" LCD Screen Replacement: 步骤 4 中的图像 1,3 Creative Ziio 7" LCD Screen Replacement: 步骤 4 中的图像 2,3 Creative Ziio 7" LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
    • Carefully lift up the circuit board on the detached side.
    • There is another ribbon cable attached to the underside of the circuit board.
    • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
    • The circuit board is extremely delicate. Move carefully and don't rush on this step!
  5. Creative Ziio 7" LCD Screen Replacement: 步骤 5 中的图像 1,1
    • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
  6. Creative Ziio 7" LCD Screen Replacement: 步骤 6 中的图像 1,1
    • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
    • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
  7. Creative Ziio 7" LCD Screen Replacement: 步骤 7 中的图像 1,2 Creative Ziio 7" LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Carefully pry the thin, metal frame from around the LCD screen.
    • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
  8. Creative Ziio 7" LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Carefully remove the black LCD screen.
结论
2等其他人完成本指南。
Kyle
于04/16/13注册
120 声望
创作了2篇指南
团队
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G10
4 名成员
创作了13篇指南
2条评论
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - 回复
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 14
总计 1,366
