跳转到主内容
Creative Ziio 7" Camera Replacement
你所需要的
  1. Creative Ziio 7" Camera Replacement, Back Panel: 步骤 1 中的图像 1,3 Creative Ziio 7" Camera Replacement, Back Panel: 步骤 1 中的图像 2,3 Creative Ziio 7" Camera Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" Camera Replacement, Camera: 步骤 2 中的图像 1,3 Creative Ziio 7" Camera Replacement, Camera: 步骤 2 中的图像 2,3 Creative Ziio 7" Camera Replacement, Camera: 步骤 2 中的图像 3,3
    • Unscrew the four 3mm Phillips #00 screws found in each corner of the motherboard.
  3. Creative Ziio 7" Camera Replacement: 步骤 3 中的图像 1,3 Creative Ziio 7" Camera Replacement: 步骤 3 中的图像 2,3 Creative Ziio 7" Camera Replacement: 步骤 3 中的图像 3,3
    • Unplug the ribbon cable near the edge of the motherboard in the bottom right of the device.
  4. Creative Ziio 7" Camera Replacement: 步骤 4 中的图像 1,2 Creative Ziio 7" Camera Replacement: 步骤 4 中的图像 2,2
    • Lift up the motherboard.
    • A mesh-like strip on the right side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip. Use tweezers or pliers to pull on the strip and unplug it.
  5. Creative Ziio 7" Camera Replacement: 步骤 5 中的图像 1,2 Creative Ziio 7" Camera Replacement: 步骤 5 中的图像 2,2
    • Lift up the motherboard and locate the ribbon cable (burnt orange-colored strip) centered on top of the motherboard.
    • The ribbon cable with the attached camera is plugged into the motherboard.
    • Unplug the ribbon cable using your fingers to pull up on the flap.
  6. Creative Ziio 7" Camera Replacement: 步骤 6 中的图像 1,2 Creative Ziio 7" Camera Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to pry the camera away from the rubber camera mount.
    • Do not remove the entire rubber camera mount. Only remove the camera attached with adhesive.
    • Remove the broken camera and use electronic-friendly adhesive to attach a new camera.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G10
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 332
