跳转到主内容
加入维修社区 - 创建账户
Creative Zen Vision W Motherboard Replacement
你所需要的
  1. Creative Zen Vision W Motherboard Replacement, Battery Removal: 步骤 1 中的图像 1,3 Creative Zen Vision W Motherboard Replacement, Battery Removal: 步骤 1 中的图像 2,3 Creative Zen Vision W Motherboard Replacement, Battery Removal: 步骤 1 中的图像 3,3
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Creative Zen Vision W Motherboard Replacement, Front Cover: 步骤 2 中的图像 1,2 Creative Zen Vision W Motherboard Replacement, Front Cover: 步骤 2 中的图像 2,2
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
  3. Creative Zen Vision W Motherboard Replacement: 步骤 3 中的图像 1,3 Creative Zen Vision W Motherboard Replacement: 步骤 3 中的图像 2,3 Creative Zen Vision W Motherboard Replacement: 步骤 3 中的图像 3,3
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
  4. Creative Zen Vision W Motherboard Replacement, LCD Screen: 步骤 4 中的图像 1,3 Creative Zen Vision W Motherboard Replacement, LCD Screen: 步骤 4 中的图像 2,3 Creative Zen Vision W Motherboard Replacement, LCD Screen: 步骤 4 中的图像 3,3
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  5. Creative Zen Vision W Motherboard Replacement: 步骤 5 中的图像 1,1
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  6. Creative Zen Vision W Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  7. Creative Zen Vision W Motherboard Replacement: 步骤 7 中的图像 1,3 Creative Zen Vision W Motherboard Replacement: 步骤 7 中的图像 2,3 Creative Zen Vision W Motherboard Replacement: 步骤 7 中的图像 3,3
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
  8. Creative Zen Vision W Motherboard Replacement, Keypad: 步骤 8 中的图像 1,1
    • Peel the orange sticker off of the motherboard.
  9. Creative Zen Vision W Motherboard Replacement: 步骤 9 中的图像 1,2 Creative Zen Vision W Motherboard Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Lift the keypad from the left side and use tweezers to slide it out to the left.
  10. Creative Zen Vision W Motherboard Replacement: 步骤 10 中的图像 1,2 Creative Zen Vision W Motherboard Replacement: 步骤 10 中的图像 2,2
    • Use a small flat head screw driver to slide the white tabs away from the ribbon cable connection.
    • Remove the ribbon cable from the keypad.
  11. Creative Zen Vision W Motherboard Replacement, Back Cover: 步骤 11 中的图像 1,1
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
  12. Creative Zen Vision W Motherboard Replacement: 步骤 12 中的图像 1,2 Creative Zen Vision W Motherboard Replacement: 步骤 12 中的图像 2,2
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
  13. Creative Zen Vision W Motherboard Replacement: 步骤 13 中的图像 1,3 Creative Zen Vision W Motherboard Replacement: 步骤 13 中的图像 2,3 Creative Zen Vision W Motherboard Replacement: 步骤 13 中的图像 3,3
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
  14. Creative Zen Vision W Motherboard Replacement, Hard Drive: 步骤 14 中的图像 1,2 Creative Zen Vision W Motherboard Replacement, Hard Drive: 步骤 14 中的图像 2,2
    • Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0.
    • Lift the metal cover off.
  15. Creative Zen Vision W Motherboard Replacement: 步骤 15 中的图像 1,3 Creative Zen Vision W Motherboard Replacement: 步骤 15 中的图像 2,3 Creative Zen Vision W Motherboard Replacement: 步骤 15 中的图像 3,3
    • Lift the white and black ribbon connection off of the motherboard.
    • The hard drive can now be removed.
  16. Creative Zen Vision W Motherboard Replacement, Motherboard: 步骤 16 中的图像 1,3 Creative Zen Vision W Motherboard Replacement, Motherboard: 步骤 16 中的图像 2,3 Creative Zen Vision W Motherboard Replacement, Motherboard: 步骤 16 中的图像 3,3
    • Remove 2 screws (3.5 mm) on the black compact flash input using a Phillips #0.
  17. Creative Zen Vision W Motherboard Replacement: 步骤 17 中的图像 1,1
    • Use a small flat head screwdriver to bend the plastic tab holding the compact flash input in place.
    • The compact flash input should pop off easily, be careful not to break it.
  18. Creative Zen Vision W Motherboard Replacement: 步骤 18 中的图像 1,1
    • Turn the device over so the side where the screen was is facing up.
    • Push on the motherboard lightly to separate it from the casing.
  19. Creative Zen Vision W Motherboard Replacement: 步骤 19 中的图像 1,2 Creative Zen Vision W Motherboard Replacement: 步骤 19 中的图像 2,2
    • Turn the device over again and pull on the motherboard very lightly.
    • The speaker will be covered in a black glue and you must cut through this in order to remove the motherboard.
  20. Creative Zen Vision W Motherboard Replacement: 步骤 20 中的图像 1,1
    • Turn the speaker on its side so it can fit through the casing and the motherboard can be removed.
  21. Creative Zen Vision W Motherboard Replacement: 步骤 21 中的图像 1,2 Creative Zen Vision W Motherboard Replacement: 步骤 21 中的图像 2,2
    • You have now removed the motherboard.
    • Speaker
结论
2等其他人完成本指南。
Tim Wilson
于04/11/13注册
143 声望
创作了6篇指南
团队
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G2
4 名成员
创作了8篇指南
2指南评论
does the creative vision W have a 44 pin hard disk connector on the main board same as creative vision m has?
leohobb - 回复 分享
If the main board on vision w hard disk connector has 44 pins as vision m has but the vision w has a zif 40 pin ribbon in to the hard disk.it make me belive that it is possible to use a zif connector style hard disk on vision M to with the hard disk cable from vision w?Or does i miss something?i want to try to use a 1.8 hard disk with around 100 GB capacity on vision M if possible
leohobb - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 36
总计 1,301
