跳转到主内容
Creative Zen Vision M Screen Replacement
你所需要的
  1. Creative Zen Vision M Screen Replacement, Opening the top: 步骤 1 中的图像 1,2 Creative Zen Vision M Screen Replacement, Opening the top: 步骤 1 中的图像 2,2
    • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
    • Unscrew and remove the two exposed Phillips head screws.
  2. Creative Zen Vision M Screen Replacement, Opening the device: 步骤 2 中的图像 1,2 Creative Zen Vision M Screen Replacement, Opening the device: 步骤 2 中的图像 2,2
    • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
    • Don't try attempt to open it from the recess between the buttons and the device.
  3. Creative Zen Vision M Screen Replacement, Disconnecting the battery: 步骤 3 中的图像 1,3 Creative Zen Vision M Screen Replacement, Disconnecting the battery: 步骤 3 中的图像 2,3 Creative Zen Vision M Screen Replacement, Disconnecting the battery: 步骤 3 中的图像 3,3
    • Disconnect the wire from the bottom device.
    • Handle with care as the wires tend to disconnect easily.
  4. Creative Zen Vision M Screen Replacement, Disconnecting the hard drive: 步骤 4 中的图像 1,1
    • In the top right corner, pull the black foam square off to separate the hard drive from the screen.
    • Handle with care as the hard drive also comes off easily.
  5. Creative Zen Vision M Screen Replacement, Unscrewing from the mother board: 步骤 5 中的图像 1,1
    • Unscrew the seven screws placed around the mother board.
    • You will need a one millimeter Phillips head screwdriver.
    • The screws are small, so keep them safely.
  6. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 步骤 6 中的图像 1,3 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 步骤 6 中的图像 2,3 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 步骤 6 中的图像 3,3
    • Flip your device upside down so that the motherboard will loosen.
    • Detach the connector from the motherboard.
  7. Creative Zen Vision M Screen Replacement, Removing the screen: 步骤 7 中的图像 1,2 Creative Zen Vision M Screen Replacement, Removing the screen: 步骤 7 中的图像 2,2
    • Tilt the screen diagonally. Separate the screen and motherboard from the device frame.
    • Lift the light gray flap to detach the screen from the motherboard.
  8. Creative Zen Vision M Screen Replacement, Seperating the digital display: 步骤 8 中的图像 1,2 Creative Zen Vision M Screen Replacement, Seperating the digital display: 步骤 8 中的图像 2,2
    • Separate the clear screen frame from the digital display.
结论
另外一个人完成了本指南。
Kirstie G
于10/12/16注册
488 声望
创作了4篇指南
团队
Texas Tech, Team 12-1, Bennett Fall 2016 Texas Tech, Team 12-1, Bennett Fall 2016 的会员
TTU-BENNETT-F16S12G1
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 1,646
