跳转到主内容
Creative Zen Vision M Hard-drive Replacement
你所需要的
  1. Creative Zen Vision M Hard-drive Replacement, Opening the top: 步骤 1 中的图像 1,2 Creative Zen Vision M Hard-drive Replacement, Opening the top: 步骤 1 中的图像 2,2
    • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
    • Unscrew and remove the two exposed Phillips head screws.
    • Do the same for the bottom plastic surrounding the bottom connector, as there are two screws under here as well.
  2. Creative Zen Vision M Hard-drive Replacement, Opening the device: 步骤 2 中的图像 1,2 Creative Zen Vision M Hard-drive Replacement, Opening the device: 步骤 2 中的图像 2,2
    • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
    • Don't try attempt to open it from the recess between the buttons and the device.
  3. Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: 步骤 3 中的图像 1,3 Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: 步骤 3 中的图像 2,3 Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: 步骤 3 中的图像 3,3
    • To detach wires from the screen, gently tug on the wires connected to the battery. They are located on the bottom half of the screen.
  4. Creative Zen Vision M Hard-drive Replacement, Disconnecting the hard drive: 步骤 4 中的图像 1,1
    • Pull black hard drive connector located at the top right.
    • Ensure, as demonstrated by the image, that the screen is safely removed first. There is an iFixit guide showing how to carefully pull apart the Creative Zen Vision M.
  5. Creative Zen Vision M Hard-drive Replacement, Removing bumpers: 步骤 5 中的图像 1,1
    • Pull off blue bumpers and connect to new hard drive
  6. Creative Zen Vision M Hard-drive Replacement, Removing hard drive connector: 步骤 6 中的图像 1,2 Creative Zen Vision M Hard-drive Replacement, Removing hard drive connector: 步骤 6 中的图像 2,2
    • Lift white flap on top of hard drive to disconnect hard drive connector.
结论
另外一个人完成了本指南。
Kirstie G
于10/12/16注册
470 声望
创作了4篇指南
团队
Texas Tech, Team 12-1, Bennett Fall 2016 Texas Tech, Team 12-1, Bennett Fall 2016 的会员
TTU-BENNETT-F16S12G1
4 名成员
创作了4篇指南
3条评论
How do you get the firmware on the new hard drive?
Selvedge - 回复
Download the firmware software from: http://support.creative.com/Downloads/we...
(Select firmware).
Then:
Close all application windows that are currently running on your computer.
Connect your player to your computer.
Double-click the downloaded file and follow the instructions on the screen.
Regards.
Brendan Eager -
I should also update the link provided. Here’s a slightly better link. Select “Zen Series” then your specific model. To flash the firmware on the new hard drive. Download the file into your local hard disk. Close all application windows that are currently running on your computer. Connect your player to your computer (with the included adapter and USB wire). Double-click the downloaded file and follow the instructions on the screen.
Brendan Eager -
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 17
过去 30 天: 45
总计 3,919
