跳转到主内容
Creative Zen Vision M Battery Replacement
你所需要的
  1. Creative Zen Vision M Battery  Replacement, Opening the top: 步骤 1 中的图像 1,2 Creative Zen Vision M Battery  Replacement, Opening the top: 步骤 1 中的图像 2,2
    • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
    • Unscrew and remove the two exposed Phillips head screws
  2. Creative Zen Vision M Battery  Replacement, Opening the device: 步骤 2 中的图像 1,2 Creative Zen Vision M Battery  Replacement, Opening the device: 步骤 2 中的图像 2,2
    • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
    • Don't try attempt to open it from the recess between the buttons and the device.
  3. Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: 步骤 3 中的图像 1,3 Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: 步骤 3 中的图像 2,3 Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: 步骤 3 中的图像 3,3
    • To detach wires from the screen, gently tug on the wires connected to the battery. They are located on the bottom half of the screen.
  4. Creative Zen Vision M Battery  Replacement, Releasing the battery: 步骤 4 中的图像 1,1
    • To begin removing the battery, move the wires out from under the black foam at the bottom of the device
  5. Creative Zen Vision M Battery  Replacement, Removing the battery: 步骤 5 中的图像 1,2 Creative Zen Vision M Battery  Replacement, Removing the battery: 步骤 5 中的图像 2,2
    • Use a plastic opening tool or nylon spudger to lift up the battery.
    • Battery may be glued on the edges.
    • The metal spudger is great for serious prying power, but the regular black nylon spudger should be used whenever possible, especially around batteries.
结论
7等其他人完成本指南。
Kirstie G
于10/12/16注册
488 声望
创作了4篇指南
团队
Texas Tech, Team 12-1, Bennett Fall 2016 Texas Tech, Team 12-1, Bennett Fall 2016 的会员
TTU-BENNETT-F16S12G1
4 名成员
创作了4篇指南
3指南评论
Step 1 does not mention that the bottom cover needs to also be removed to access two more screws. Make note of the screw lengths and where they come from.. Two are shorter.
Bob Terwilliger - 回复
Seconding this, if you try to separate the top and bottom covers before unscrewing the two screws to the sides of the charging/data port you may damage your device irreparably. In my case I had already watched a guide online and I did not damage mine, but after so many years the plastic has degraded and it's very easy to see how you could do some serious damage if you're not careful.
valpampa -
Does anyone know, what do you do if the existing battery goes completely flat, and the unit will not charge. I believe the battery needs replacing. Are these batteries available, and if they do, what is the shelf life of a new battery?
Carl MacCulloch - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 94
总计 6,631
