跳转到主内容
Creative Zen V Plus Logic Board Replacement
你所需要的
  1. Creative Zen V Plus Logic Board Replacement, Prerequisite Only: 步骤 1 中的图像 1,1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Logic Board Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Logic Board Replacement: 步骤 3 中的图像 1,1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Logic Board Replacement: 步骤 4 中的图像 1,2 Creative Zen V Plus Logic Board Replacement: 步骤 4 中的图像 2,2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Logic Board Replacement: 步骤 5 中的图像 1,1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Logic Board Replacement: 步骤 6 中的图像 1,3 Creative Zen V Plus Logic Board Replacement: 步骤 6 中的图像 2,3 Creative Zen V Plus Logic Board Replacement: 步骤 6 中的图像 3,3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Logic Board Replacement, Logic Board: 步骤 7 中的图像 1,1
    • Unplug the logic board from the battery. Replace the logic board with your new logic board and reassemble your device.
结论
Joel Ng
于10/19/16注册
245 声望
撰写一个指南
团队
IUPUI, Team 2-5, Baechle Fall 2016 IUPUI, Team 2-5, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S2G5
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 634
