跳转到主内容
Creative Nomad Jukebox Zen Display Screen Replacement
你所需要的
  1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: 步骤 1 中的图像 1,3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: 步骤 1 中的图像 2,3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: 步骤 1 中的图像 3,3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Display Screen Replacement: 步骤 2 中的图像 1,3 Creative Nomad Jukebox Zen Display Screen Replacement: 步骤 2 中的图像 2,3 Creative Nomad Jukebox Zen Display Screen Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: 步骤 3 中的图像 1,1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: 步骤 4 中的图像 1,1
    • Using the plastic opening tool to pop the metal tab holding the battery in place.
    • By breaking the sticker, it could void your warranty
  5. Creative Nomad Jukebox Zen Display Screen Replacement: 步骤 5 中的图像 1,2 Creative Nomad Jukebox Zen Display Screen Replacement: 步骤 5 中的图像 2,2
    • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
  6. Creative Nomad Jukebox Zen Display Screen Replacement: 步骤 6 中的图像 1,2 Creative Nomad Jukebox Zen Display Screen Replacement: 步骤 6 中的图像 2,2
    • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
    • Using soldering gun with care as it becomes extremely hot and can cause burns.
  7. Creative Nomad Jukebox Zen Display Screen Replacement: 步骤 7 中的图像 1,1
    • Using the spudger tool, gently pry up the corners of the display screen to remove it.
结论
Austin Shaw
于03/08/17注册
101 声望
撰写一个指南
团队
IUPUI, Team S4-G5, Baechle Spring 2017 IUPUI, Team S4-G5, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S4G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 525
