跳转到主内容
Creative Nomad II Headphone Jack Replacement
你所需要的
  1. Creative Nomad II Headphone Jack Replacement, Battery: 步骤 1 中的图像 1,1
    • Using your thumb, slide down and remove the battery cover.
  2. Creative Nomad II Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Using your index finger, remove the old AA battery.
    • Install the new AA battery.
  3. Creative Nomad II Headphone Jack Replacement, Smart Media Card: 步骤 3 中的图像 1,1
    • Slide down the eject button.
    • Pull out the old SmartMedia Card.
    • Insert the new SmartMedia Card.
    • The notched corner of the SmartMedia card should go in the top left corner.
  4. Creative Nomad II Headphone Jack Replacement, Back Cover: 步骤 4 中的图像 1,1
    • Using a Phillips #00 Screwdriver, remove the two 7.5 mm screws located on the left and right side of the back cover, respectively.
  5. Creative Nomad II Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Remove the back cover of the Nomad II.
    • Remove the following items located on the left and right side of the device:
    • The rubber USB port cover
    • The plastic lock/unlock switch cover
    • The buttons located on the left side of the device
  6. Creative Nomad II Headphone Jack Replacement, Battery Compartment: 步骤 6 中的图像 1,1
    • Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located in the bottom corners of the battery compartment.
  7. Creative Nomad II Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • Using your fingers, carefully remove the battery compartment.
  8. Creative Nomad II Headphone Jack Replacement, Circuit Boards: 步骤 8 中的图像 1,1
    • Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located on the left and right edges of the circuit board.
  9. Creative Nomad II Headphone Jack Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using a pair of tweezers, carefully remove the metal loop attached to the circuit board from its plastic case on the left side of the battery compartment.
  10. Creative Nomad II Headphone Jack Replacement: 步骤 10 中的图像 1,1
    • Pull out the circuit boards.
    • When reinserting the circuit boards, press the front face of the boards into the device case until you hear a click.
  11. Creative Nomad II Headphone Jack Replacement: 步骤 11 中的图像 1,1
    • Position the circuit boards with the USB port facing up.
    • Gently separate the circuit boards.
  12. Creative Nomad II Headphone Jack Replacement, Headphone Jack: 步骤 12 中的图像 1,1
    • Using a pair of tweezers, gently lift and peel back the thin copper film covering the headphone jack.
    • Only peel back the film enough to expose the headphone jack.
    • Completely removing the copper film can damage the device.
  13. Creative Nomad II Headphone Jack Replacement: 步骤 13 中的图像 1,1
    • Gently remove the black adhesive tape from the underside of the headphone jack.
  14. Creative Nomad II Headphone Jack Replacement: 步骤 14 中的图像 1,1
    • Desolder the four solder joints securing the headphone jack.
    • Remove the old headphone jack.
    • Install the new headphone jack.
结论
Craig Fischer
于01/24/12注册
21 声望
创作了2篇指南
团队
Cal Poly, Team 9-2, Regan Winter 2012 Cal Poly, Team 9-2, Regan Winter 2012 的会员
CPSU-REGAN-W12S9G2
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 1,539
