跳转到主内容
加入维修社区 - 创建账户
Creating a Bootable SD Card
你所需要的
  1. Creating a Bootable SD Card, Downloading Raspberry Pi Imager: 步骤 1 中的图像 1,3 Creating a Bootable SD Card, Downloading Raspberry Pi Imager: 步骤 1 中的图像 2,3 Creating a Bootable SD Card, Downloading Raspberry Pi Imager: 步骤 1 中的图像 3,3
    • To create our Bootable SD Card we will need the Official Raspberry Pi Imager software. This software is completely free, and can be downloaded here.
    询问修复机器人
    添加评论
  2. Creating a Bootable SD Card, Configuring your SD Card: 步骤 2 中的图像 1,1
    • Once your download has been completed, open the Pi Imager program, and insert your SD Card into your computer. The Imager software should automatically detect your SD Card, and will begin to format the card.
    • Formatting your SD Card will erase any content that has been saved onto the card. Be sure to backup any photos or files to your machine before formatting.
    询问修复机器人
    添加评论
  3. Creating a Bootable SD Card, Select your Operating System: 步骤 3 中的图像 1,2 Creating a Bootable SD Card, Select your Operating System: 步骤 3 中的图像 2,2
    • Once your SD Card has been targeted, you'll need to select the Operating System that you would like loaded onto your SD Card.
    • Imager comes pre-loaded with several operating systems, however you can select a custom OS by scrolling to the bottom of the list of OS'.
    询问修复机器人
    添加评论
  4. Creating a Bootable SD Card, Choosing your SD Card: 步骤 4 中的图像 1,2 Creating a Bootable SD Card, Choosing your SD Card: 步骤 4 中的图像 2,2
    • Once your OS has been selected, select your inserted SD card.
    询问修复机器人
    添加评论
  5. Creating a Bootable SD Card, Writing the OS to your SD Card: 步骤 5 中的图像 1,2 Creating a Bootable SD Card, Writing the OS to your SD Card: 步骤 5 中的图像 2,2
    • Once you have your SD Card selected, click on the Write button. If prompted enter the password to your computer.
    • This step will erase any data that is on the SD Card. Be sure to back up any files or photos you wish to save to your computer
    询问修复机器人
    添加评论
    • When the installation is complete, Imager will prompt you to remove your SD Card.
    • Imager will automatically eject your SD Card, so it should be safe for you to remove it once the installation is complete.
    • To begin using your Bootable SD Card, simply insert the card into your Raspberry Pi, and power on your device.
    询问修复机器人
    添加评论
    • It is possible that at the moment you begin to WRITE the OS to your SD Card an alert may appear warning that the card is write protected. This happens when the switch on the left side of the SD is in protection mode.
    • You can solve this by ejecting the SD Card and move the lever to the side opposite, then repeat the OS selection operation. and of the SD Card.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
由衷感谢以下译者:
it en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Ema.exe
于06/19/22注册
538 声望
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 80
总计 1,970
