跳转到主内容
加入维修社区 - 创建账户
Creating Apple Lisa KeyCaps
你所需要的
  1. Creating Apple Lisa KeyCaps, Selecting Keys: 步骤 1 中的图像 1,2 Creating Apple Lisa KeyCaps, Selecting Keys: 步骤 1 中的图像 2,2
    • My keyboard was missing a variety of keys so I needed to select source keys to create the molds. On the 2nd image all the like-keys are color-coded.
  2. Creating Apple Lisa KeyCaps, Base Mold: 步骤 2 中的图像 1,1
    • Mix enough putty that the source key will fit in. Make sure the edge of the key is flush with the top of the putty to ensure the key is the correct size.
  3. Creating Apple Lisa KeyCaps, Connector Mold: 步骤 3 中的图像 1,1
    • Once the base mold is set, mix a tiny amount of putty to press down into the key. Unseen in this photo: press the putty down right to the pegs of the source key so they are poking holes in the top of the mold.
    • Put on a pair of disposable rubber gloves or you’ll be peeling off the resin from your fingers for weeks.
  4. Creating Apple Lisa KeyCaps, Casting: 步骤 5 中的图像 1,1
    • Mix a tiny amount of resin as directed on the bottle. Ensure you are measuring accurately. Pour the resin into the base mold until 3/4th filled. Put the top mold on top of the base mold as to cast the connector onto the mold. Unseen in this photo is the correct top mold with the exposed holes on top. Pour liquid resin into the top to fill the holes
  5. Creating Apple Lisa KeyCaps, Setting Up: 步骤 6 中的图像 1,1
    • After about half an hour remove the key from the mold and set aside to finish setting up. Be careful not to snap the connectors off when removing from mold. Sand off the edges if needed.
  6. Creating Apple Lisa KeyCaps, Painting: 步骤 7 中的图像 1,1
    • Once the key(s) have set up, you can now paint. Be careful not to overpaint which will lead to the key being too thick.
  7. Creating Apple Lisa KeyCaps, Fitting: 步骤 8 中的图像 1,1
    • Assemble the keys to ensure they work before writing the key symbols. If you need replacement springs, I suggest the spring kit (listed in the parts section.) it has 8 useable springs per kit for this kind of project.
  8. Creating Apple Lisa KeyCaps, Key Symbols: 步骤 9 中的图像 1,1
    • Once you are happy with the keys, use a fine tip sharpie to write the key symbols. Let the sharpie dry for a day.
结论
While crude, they work quite well especially after you spend a huge amount of time online realizing there are no places to buy replacement keycaps.
LisaGuide
于12/30/18注册
1,833 声望
创作了11篇指南
1指南评论
No, the results are unfortunately not convincing (sorry to say that). Maybe it is better using a 3D printer for this ...?
Peter Mueller - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 722
