跳转到主内容
Create a Bootable USB Stick from an Older Version of macOS
  1. Create a Bootable USB Stick from an Older Version of macOS, Create a Bootable USB Stick from an Older Version of macOS: 步骤 1 中的图像 1,1
  2. Create a Bootable USB Stick from an Older Version of macOS: 步骤 2 中的图像 1,1
    • Open InstallMacOSX.dmg by double-clicking.
    • Double-click on InstallMacOSX.pkg
    • The installer runs
  3. Create a Bootable USB Stick from an Older Version of macOS: 步骤 3 中的图像 1,1
    • If you don't get the following error: "This version of OS X/macOS cannot be installed on this computer."
    • Wait for the end of the installation and follow the following tutorial : 创建一个USB启动盘
    • Otherwise, go to the next step.
  4. Create a Bootable USB Stick from an Older Version of macOS: 步骤 4 中的图像 1,1
    • Quit the installer and drag and drop the InstallMacOSX.pkg file on your Desktop
  5. Create a Bootable USB Stick from an Older Version of macOS: 步骤 5 中的图像 1,2 Create a Bootable USB Stick from an Older Version of macOS: 步骤 5 中的图像 2,2
    • Open Terminal and enter the following command: "cd Desktop"
    • Enter the following command: "pkgutil --expand /Desktop/InstallMacOSX.pkg FolderName" (You can change FolderName to any name you want)
    • A folder with the name you gave appears on your Desktop.
  6. Create a Bootable USB Stick from an Older Version of macOS: 步骤 6 中的图像 1,3 Create a Bootable USB Stick from an Older Version of macOS: 步骤 6 中的图像 2,3 Create a Bootable USB Stick from an Older Version of macOS: 步骤 6 中的图像 3,3
    • Open the folder appeared on the desktop.
    • Open the "Distribution" file with TextEdit.
    • Look for the line with "var platformSupportValues"
  7. Create a Bootable USB Stick from an Older Version of macOS: 步骤 7 中的图像 1,2 Create a Bootable USB Stick from an Older Version of macOS: 步骤 7 中的图像 2,2
    • Let TextEdit open and go to the Terminal and enter the following command: "ioreg -l | grep -i board-id"
    • Copy "Mac-XXXXXXXX"
    • Go back to TextEdit and after the symbol "=" and in the brackets paste "Mac-XXXXX" and add a comma ","
    • Save and close the file
  8. Create a Bootable USB Stick from an Older Version of macOS: 步骤 8 中的图像 1,2 Create a Bootable USB Stick from an Older Version of macOS: 步骤 8 中的图像 2,2
    • Go back to the terminal and type the following command: pkgutil --flatten FolderName New.pkg (FolderName = the name of the folder and New.pkg = the new .PKG file that will be created)
    • Press enter and wait for the file to be created
    • Launch the new .PKG file
    • Congratulations you can launch the installer.
    • To continue creating the USB Stick follow the following tutorial : 创建一个USB启动盘
结论
You're done BRAVO !!
3等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
Anthony Fassler正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Anthony Fassler
于02/26/15注册
6,317 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 204
过去 30 天: 905
总计 3,209
