跳转到主内容
Creality Ender 3 V2 Extruder Nozzle Replacement
你所需要的
  1. Creality Ender 3 V2 Extruder Nozzle Replacement, Extruder Nozzle: 步骤 1 中的图像 1,1
    • Move the extruder carriage to the center of the machine.
  2. Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 2 中的图像 1,1
    • Use a 2 mm Allen wrench to remove the two screws located on the back of the extruder shroud.
  3. Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the shroud by pulling it away from the hot end of the 3D printer.
  4. Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 4 中的图像 1,3 Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 4 中的图像 2,3 Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 4 中的图像 3,3
    • Remove the silicon sleeve around the heat block.
    • Before removing the nozzle, you must bring the printer up to operating temperature in order to remove the leftover filament from the extruder.
  5. Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 5 中的图像 1,2 Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 5 中的图像 2,2
    • Once the excess filament has been removed, loosen the nozzle by a quarter turn using the wrench provided, then either power off or cool down the printer.
    • Do not attempt to fully remove the nozzle while the printer is at operating temperature. Allow the nozzle to fully cool before removal.
  6. Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 6 中的图像 1,3 Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 6 中的图像 2,3 Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 6 中的图像 3,3
    • Before removing the nozzle check the temperature by bringing the back of your hand near the nozzle; do not touch it. If you feel any heat on the back of your hand, then wait another 10-15 minutes before removing the nozzle.
    • If the nozzle is fully cooled, remove the nozzle.
  7. Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 7 中的图像 1,2 Creality Ender 3 V2 Extruder Nozzle Replacement: 步骤 7 中的图像 2,2
    • Screw on the new nozzle into the heat block with your wrench.
    • To fully tighten the nozzle, bring the printer back to operating temperature and do a final tightening of the nozzle.
    • Printer must be at operating temperature when fully tightening in order to prevent leaks in the future.
结论
Print away!
7等其他人完成本指南。
团队
UMass Dartmouth, Team S2-G3, Riel Spring 2021 UMass Dartmouth, Team S2-G3, Riel Spring 2021 的会员
UMASSD-RIEL-S21S2G3
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 130
过去 30 天: 637
总计 17,572
