跳转到主内容
Creality CR-20 X Gantry Alignment
你所需要的
  1. Creality CR-20 X Gantry Alignment, X Gantry Alignment: 步骤 1 中的图像 1,3 Creality CR-20 X Gantry Alignment, X Gantry Alignment: 步骤 1 中的图像 2,3 Creality CR-20 X Gantry Alignment, X Gantry Alignment: 步骤 1 中的图像 3,3
    • The CR-20 Pro has solid bed mounts. If any X axis gantry alignment is needed, you can use the "nozzle to bed" distance to check.
    • With M2.5 hex, loosen the 2 button head screws on the back side/ right of the X/Z Bracket.
    • If the right side is too low and needs to go up, squeeze the bracket and rail together while tightening the button head screws.
    • If the right side is high and needs to be lowered, you will squeeze the bottom wheel against the X rail while tightening.
    • When properly adjusted, the nozzle will be the same distance from the bed from left to right.
    • In some cases, it is necessary to do this process on the left side (near extruder motor) but requires partial disassembly of the machine.
结论
Tiny Machines 3D
于11/16/19注册
2,970 声望
创作了14篇指南
团队
Tiny Machines 3D Tiny Machines 3D 的会员
Community
5 名成员
创作了40篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 1,145
