跳转到主内容
Crayola Crayon Maker White Plastic Arm Replacement
你所需要的
  1. Crayola Crayon Maker White Plastic Arm Replacement, Take out the melting tray that is out of place.: 步骤 1 中的图像 1,3 Crayola Crayon Maker White Plastic Arm Replacement, Take out the melting tray that is out of place.: 步骤 1 中的图像 2,3 Crayola Crayon Maker White Plastic Arm Replacement, Take out the melting tray that is out of place.: 步骤 1 中的图像 3,3
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker White Plastic Arm Replacement, Remove the metal melting tray.: 步骤 2 中的图像 1,3 Crayola Crayon Maker White Plastic Arm Replacement, Remove the metal melting tray.: 步骤 2 中的图像 2,3 Crayola Crayon Maker White Plastic Arm Replacement, Remove the metal melting tray.: 步骤 2 中的图像 3,3
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker White Plastic Arm Replacement, Remove the light bulb: 步骤 3 中的图像 1,3 Crayola Crayon Maker White Plastic Arm Replacement, Remove the light bulb: 步骤 3 中的图像 2,3 Crayola Crayon Maker White Plastic Arm Replacement, Remove the light bulb: 步骤 3 中的图像 3,3
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
  4. Crayola Crayon Maker White Plastic Arm Replacement, Remove the green base from the crayon maker: 步骤 4 中的图像 1,3 Crayola Crayon Maker White Plastic Arm Replacement, Remove the green base from the crayon maker: 步骤 4 中的图像 2,3 Crayola Crayon Maker White Plastic Arm Replacement, Remove the green base from the crayon maker: 步骤 4 中的图像 3,3
    • Flip the crayon maker.
    • Remove six screws (2 cm in length) with a spanner.
    • Remove the green base plate and set it aside.
  5. Crayola Crayon Maker White Plastic Arm Replacement, Locate the Plastic arm: 步骤 5 中的图像 1,3 Crayola Crayon Maker White Plastic Arm Replacement, Locate the Plastic arm: 步骤 5 中的图像 2,3 Crayola Crayon Maker White Plastic Arm Replacement, Locate the Plastic arm: 步骤 5 中的图像 3,3
    • Locate the clear plastic arm inside the control box.
  6. Crayola Crayon Maker White Plastic Arm Replacement, Adjust/Replace the Plastic Arm: 步骤 6 中的图像 1,2 Crayola Crayon Maker White Plastic Arm Replacement, Adjust/Replace the Plastic Arm: 步骤 6 中的图像 2,2
    • If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached.
    • If the plastic arm is broken, contact Crayola for replacement parts.
  7. Crayola Crayon Maker White Plastic Arm Replacement, Locate the clear plastic box: 步骤 7 中的图像 1,3 Crayola Crayon Maker White Plastic Arm Replacement, Locate the clear plastic box: 步骤 7 中的图像 2,3 Crayola Crayon Maker White Plastic Arm Replacement, Locate the clear plastic box: 步骤 7 中的图像 3,3
    • Remove the green base from the crayon maker and set aside.
    • Locate the clear box.
  8. Crayola Crayon Maker White Plastic Arm Replacement, Remove clear box.: 步骤 8 中的图像 1,2 Crayola Crayon Maker White Plastic Arm Replacement, Remove clear box.: 步骤 8 中的图像 2,2
    • There are four screws (circled in red) that need to be removed with a Phillips #00 Precision screwdriver.
  9. Crayola Crayon Maker White Plastic Arm Replacement, Open Clear Plastic Box: 步骤 9 中的图像 1,1
    • Remove five screws (1.5 cm in length) using a Phillips #00 Precision screwdriver and open the clear plastic box.
  10. Crayola Crayon Maker White Plastic Arm Replacement, Check placement of white plastic arm.: 步骤 10 中的图像 1,1
    • The plastic arm should be positioned as shown in the figure. Adjust the arm's position if necessary.
    • If the plastic arm is broken, contact Crayola for a replacement arm.
结论
另外一个人完成了本指南。
Melissa
于10/10/14注册
210 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 655
